DaddyAirtime
- Joined
- Jul 20, 2012
- 20
Hello all, new here. I purchased a 2006 Larson 208 LXi last year. Engine is 5.0 GXi-F. I have taken it out many times and it has always had a belt squeal that comes from the power steering pump. The squeal goes away after some time running the boat. I just assumed it was loose and the tensioner was doing it's job. The last time out with the boat the belt was very loud so I decided to spray some belt lube on it. Bad idea. The belt squealed so loud I thought it was an air raid. It continued to squeal very loudly for some time. When I got off the water I took a closer look at the power steering pulley and it looks like it is recessed compared to all the other pulleys on the belt. It looks to me like the belt has to move inboard when on this pulley causing an angle and the side of the belt contacts the pulley edge.
Question: Are all the pulleys supposed to be on the same plane/level? Would this be causing my belt squeal? Is it bad to have one pulley out of alignment and is this a DIY job? I have the engine manual and I am very handy.
Thank you for your attention.
-Tony C
-Tony C
