I have a 1987 johnson j90tlcur. Took out the vro pump and replaced with part# 0438556. Going from the pump to the carb plastic manifold causes a severe bend and kink in the 5/16 hose. I'm coming out of the bottom of the pump, then up the back of the air box and making a 180 degree turn where the vro pump was to get to the plastic carb manifold. Is there a type of fuel line that can be bent by hand with out kinking or some type of fitting that makes a 180 degree turn like the factory fuel filter on this motor?
