Bendix Engaged
Ribs
I have a 92 Evinrude 40 that the bendix will not disengage. I have tried oiling the shaft and rotating the bendix but, it will not budge. Any suggestions?<br /><br />Thanks,<br /><br />Mike
mike69infl
Re: Bendix Engaged
is there wear on the bendix, if so you might have to pry it with a screwdriver to get it down. Does the engine have a hard time starting?
mike69infl
Re: Bendix Engaged
i didnt mean to pry it down, i meant that you have to try to turn it while putting downward pressure on it.
Ribs
Re: Bendix Engaged
The bendix appears to be fine(externally) and the engine is a good starter.
mike69infl
Re: Bendix Engaged
are the teeth on the bendix lining up with the voids on the flywheel or are they slightly offset?
Ribs
Re: Bendix Engaged
I will have to check the alignment. I am currently at work.
mike69infl
Re: Bendix Engaged
i had a similar problem, and once i was able to work it free, i replaced it( approx. $20) and no problems since.
Ribs
Re: Bendix Engaged
Thanks,<br /><br />I think I will have to replace it.
