nslsubject
- Joined
- Jul 31, 2007
- 14
No, they are not related (as far as I know). I have a 1993 Evinrude 90/65 model# E90JLETS with two problems:
1) The bendix gear is pretty chewed up and sometimes jams in the flywheel teeth (which are in good shape) when I try to start. It jams tight enough that the starter won't spin, won't slide up farther or back into place. While it's a simple enough matter to pop the engine cover and free the gear, it seems like the right thing to do is replace the offending bendix. Can I replace just the gear on top of the starter shaft? Is it as easy as it looks by removing locknut, nut, gear? Any idea of the price for one?
2) I have acquired a constant warning horn upon turning the key on. When I unplug both temp switch leads, it still blares. There is no obvious short in the tan wire on the wiring harness but I haven't gotten an electrical tester yet to check where I can't see. My question is this - if I need to test/replace one or both temp switches, how do I remove them? The leads seem to come directly out of some spongy foam plug without any obvious means of removal. I just got an OMC manual for my engine, looked in the "test your temperature switch" section and found the helpful advice, "Remove temperature switch." The manual apparently assumes that I have some working knowledge of my engine, (which I obviously don't or I wouldn't be asking).
I'd appreciate any info from you who DO have some working knowledge.
Thanks
Thanks
