Re: bendix gear slipping - Presto lite starter
Well, first I need to correct myself. The internals of the lower collar on the bendix is probably a one-way clutch. It would function to prevent the starter motor from overspeed when the engine fires and before the bendix disengages. It would probably also be a safety in case the operatot keeps the starter engaged after the engine starts.
It would PROBABLY consist of two rollers on a cam. when the starter turns, the cam forces the rollers out to the perimeter where they lock-up like a clutch. When the engine spins the bendix the opposite direction, the rollers disengage. Now, of course, if the rollers do not engage but skid along the perimeter, a lot of heat will be generated.
The top nut can be re-used, I have done so numerous times with no ill effects but be certain you get it on tight again.
Since the stator acts like a magneto, if the starter turns the engine too slowly, the CD charge coils in the stator will not generate a high enough voltage for positive starts. For this and other reasons, normal cranking speed is between 350-550 RPM.
