On the starter at top. You have the nut, then spring, then a washer of sort, then the gear that turns flywheel, then another gear under, with angled teeth that the gear that turns flywheel rotates on and rides up to flywheel. I see these parts in my parts manual. On my actual starter I do not see the washer. It seems to me this washer with the spring above it, holds down the gear that turns the flywheel down after it starts. Well when Mine starts the gear rides up the gear under it with the angle teeth. To where it slightly touches the flywheel and causes sparks. I do not see the washer on it. I think this is what hold the gear down by the spring behind it putting preassure down on washer, that in turn hold down gear. Is this correct? Can I just but this washer and put it on to correct my problem?
If not can I have this rebuilt at any local starter shop? Can it even be rebuilt being it is old? What would something like this cost? Any of you guys do things like this?
