Re: Benifits of Tilt and Trim
Porpoising is caused by condition where the boat rides up on plane, but is unstable at speed, it falls down, and the cycle repeats. Like you experience, the "higher" the motor trims, the more likely and pronounced porpoising becomes. There are two basic steps to take to reduce porpoising.<br /><br />1) Redistribute weight in the boat. If the front is light and the back is heavy, move weight to the bow. The heavier front will be less likely to "bounce around" on the water and act more stable.<br /><br />2) Adjust the trim properly. Bringing in the trim (bringing the motor closer to the transom) will force the bow down and the back up, reducing bow bounce and leveling the boat. Thats how the average boat should ride.<br /><br />A combination of these two are what all but eliminated the porpoising in my boat. It is still there under light loads and WOT, but not enough to be an issue. With a full tank of gas it's practically non existant.<br /><br />Play around with setting and loading. If it doesn't help, trim tabs might be needed.<br /><br />Someone else can give you a better explanation of porpoising. Mine was kind of simple.
