So last fall I pulled the trim tab switch out of the boat and brought it home to clean it up. One of the screws holding the copper strip - bus bar of sorts - was missing, another was loose, and the whole thing was corroded. After taking everything apart and cleaning it up, I don't remember which side is up. If I am looking at the front side of the switch and can read it "right side up", if I were to flip the switch over about it's 'y' axis, should I be able to read the Y,B,R, and G right side up as well? In other words, the letters front and back are both oriented in the same direction. This would make the most sense, but I just want to check. Also, since I had issues before, should I use a little loctite?
Thanks!
Thanks!
