Bennett Tab upper hinge seal
62cruiserinc
I am replacing the upper hinge on my Bennett tabs and need recommendations on a sealer for the hinge-to-hull joint.
Bennett says just to use a "sealer". I have an opportunity to do this today before a bunch of rainy days coming.
The only marine sealant available locally is 3m 5200, which definitely would work but is permanent.
The other option, 3m 4000/4200 is not available locally.
Has anyone used any other sealants in a similar application?
I don't want to use a silicone as they are not rated for constant immersion, even though these upper hinges will be just above the water line.
Thanks
Steve
I used 3M 4200 when replacing my tab hinges. Don't use 5200 because will not come apart again without damage if ever need it
i have used 5200/4200 and 4000UV.
the 5200 and 4200 will break down with UV light if your boat is stored on a trailer.
you can use one of the available debonders to loosen 5200 if you need.
The Bennett hinge can be completely exposed to sunlight 24-7 and the adhesive will never be exposed to it. The hinge covers all holes.
fetch
fetch
crazy charlie
Use what you got,the 5200 will be fine.Dont use too much.BTW it is a bond that can be taken apart by you,it just wont come apart by itself .Thats the "permanent" bond spoken of.Charles
