Hi guys,
Yesterday as I'm coming back from Catalina island and once inside the harbor my outboard (Honda BF150 4stroke) started making an odd noise and vibrating. This was at very low RPMs and 5 mph. When I flushed the motor I asked my friend to put it in gear and noticed that the prop was wobbling a bit. I took the prop off the motor and run it and the shaft seems to turn straight. The issue is that the prop also seems to be straight with absolutely no nicks or dings. Before I send it in to be fixed, do you have any advise? Could it be spun? Or just a bad hub? The boat was very heavy with 4 guys with spearfishing and scuba gear but like I said, the problems started to happen at very low speeds and I never heard any noises that would indicate hitting something. Maybe something got wrapped on the prop and spun the hub?
I can upload a video if needed.
Any help is greatly appreciated.
