Bent Prop Shaft
ircrazyandweird
I was getting water in the oil in the lower unit so I rebuilt it with new seals and gaskets. I tested it and it leaks. I noticed that the shaft where the propeller attaches, it is slightly bent. Is there anyway to get this fixed ir do I have to get a new one. I have a 1970 Chrysler 35hp. Thanks
eurolarva
Re: Bent Prop Shaft
Keep an eye out on ebay for a complete lower unit. A 35,45 and 55 HP should work on your motor
scotiany
Re: Bent Prop Shaft
There's just what you need on ebay right now and it's new. Look under Chrysler outboard.
