Re: Bent Prop.
Define the size of the dent (as big as a dime etc). Is the blade itself bent? are you experiancing driveline vibration? Some of the small nicks can be smoothed out using a file. If you are in any doubt I would remove the prop and have it reconditioned. That will be about a $50-$75 investment in security. A rebuilt outdrive is about $1400 so the lower cost is worth it. Many of us also carry a spare (used or cheap prop) for emergencies. If you want to "improve" your performace slightly then buy a stainless steel prop and keep the old one as a spare. <br /><br />Bob
