bent push rod problem
rewdan
if I have bent a push rod following water in the cylinder, does anyone know what the signs would be to show it is bent. Also can running the engine do further damage if it is bent?
John_S
Re: bent push rod problem
I have no idea what motor you are talking about, but it is usually obvious once valve cover is off. Otherwise, rolling them on a glass pane will show if it is out of round.
rewdan
hi, thanks for the response, could you have a look at my other post on this-
'could i have done any other damage ' posted by rewdan
that I put on yesterday, it explains it more deeply and I could really do with the advice.
Thanks
6meter
The rocker arm could be pushed to one side. When the valve is closed it could be loose.
