Cajunrebel
- Joined
- Jun 16, 2015
- 4
So over the weekend we took my boat out (16 ft Thundercraft with a 78 Johnson 85) for the first time since bringing it back from the dead. The trip went with only a few minor hiccups until we put the boat back on the trailer. We forgot to raise the motor when we pulled out of the launch. The motor got dragged along the ramp and the skeg and prop got damaged. The rear tip of the skeg is bent significantly and the prop has a fair bit of runout when spun by hand and also scrapes the lower unit. There is an old boat mechanic near where I store my boat on base and I stopped by so that he could see it. Now keep in mind that this guy works for the base and what he tells me is not motivated by money. I pulled the prop off and we can see that the bushing in the hub was pushed off center a fair bit. I do not know of any local place that can repair the prop so I may be getting a new one. For the new one he recommended a 14 x 17 in place of the damaged 13.25x17. He also told me that my prop is an old design with a pressed in bushing and that there is a new design that has a more easily serviced bushing. However if it is a simple press out the old and press the new one in I do own a shop press.
Now for the skeg he recommended bending it back into shape with a pair of hammers. I was thinking of cutting off the damaged portion and welding on a repair section in its place using the spool gun on my mig welder. What would everyone here recommend? I am a well skilled mechanic (F-16 Crew Chief by trade) so I'm not affair of any level of tearing into a motor.
