accentphoto
- Joined
- May 4, 2011
- 128
I just bought this off of a guy damaged only because it was low use looking and it came from inland and never saw salt (unlike mine). He was trailering it from a Bass competition and jack knifed his boat off of the road. He mentioned that he used to use transom savers but a friend showed him how to do a better version using what he called 1" water pipe. Not sure if he was talking about PVC or what. Anyways ... the motor came flying off in the wreck and you see the part that I bought. The white think that looks like a crack is a spider web. The unit does in fact look very good except for the bent and broken parts.
So, how can I straighten these without doing more harm to the shaft as far as cuts and scratching goes? Any idea if this needs only a hammer? Does the shaft need to be pulled out and then banged? Any hints for a simple spanner tool that I can make or buy cheaply? I do have mine but it is in such bad shape from salt water that I never knew the shafts had some type of ball on the end. Mine are flat and rusty looking. I am thinking the large shaft with the connector ripped off should just be replaced with mine.
Any suggestions on how to flush something like this to make sure its clean while its off (his fluid tank got busted off and its been open but not in the weather)? Sorry for a lot of questions but I did learn a lot about the power of hydraulics and what you need to do to keep it working. All I know is that it needs clean fluid, a clean inside and lots of precision parts fitting together. Rough trim unit is mine.
