Re: bering carrier on '74 85 hp johnson
The next size bigger tap works well when those bearing carrier threads strip (or the puller bolt has to be drilled out). Heat it up good & let it cool a few times, even over a couple days, all the while keeping the puller on good and tight. <br /><br />Be patient, give it a few hot/cold cycles to break stuff loose, it'll slide out of there. <br /><br />I keep the puller real short, minimizing the tendency for it to tilt to one side.
