Berrymans b12 fuel treatment
Johnson110
Question, Prior to filling the boat ( 5.7 mercruiser ) with gas I plan on adding 2 cans of Berrymans B12 to the fuel, boat runs fine I wanted to give the fuel system a cleaning, Is this a good idea or not?
Re: Berrymans b12 fuel treatment
Ayuh,... It is if yer the folks sellin' Berryman's B12....
mkast
Yes but will it HURT anything ?
I am absolutely positive, if you don't use it, nothing will happen.
Just curious, what makes you think the fuel system needs a cleaning?
Ayuh,... The ethanol in our gas is solvent enough to clean any crud outa the system...
Fresh filters will Help more than any "Mechanic in a Can" will...
mkast
I often wondered about that, how much help can you get from someone in the john?
Johnson110
I put some in to help remove any moisture than may be in the tank from last year !
