Best 19 pitch prop for 5.0 merc with alpha one
DollarBoat
Hey I am looking to get a little more top end speed out of my Sea Ray Express Cruiser 215 with a 5.0 Merc efi and alpha one. Right now I am doing about 30 mph at 3800 rpms. I was told I should look at getting a 19 pitch three blade stainless prop. Is this good for the setup of my boat? Any other recommendations? And what brand/models of props should I look for? Thanks.
flyingscott
What prop is on it now and you might want to check your tach or your motor is way over propped. I think the operating range of your motor should be up around 4800 rpm with that motor. I could be wrong but I would check that.
flyingscott
Ok now you are way under propped as I am pretty sure the upper range for your motor is 4800 RPM. Check the tach and call the dealer see prop what they recommend.
DollarBoat
What diameter of propeller do you think I should get? Is a 14" the right size?
steelespike
This is like pulling teeth.What is the speed at 5600 ?
5600 is way too much. Calculates at 48 mph.?
Unfortunately speed at 3900 doesn't mean much.
If the prop is advertised for an Alpha One it should fit.
steelespike
Don't do a prop until you confirm your rpm we can estimate rpm from the gps speed at 5600.
Diameter changes with pitch as pitch goes up diameter goes down.I'm inclined to think a 17" at 14"diameter is likely not the right prop.
theBrownskull
If the RPM's are correct that is to high for that engine. It should be 4600-5000 range. What year is the boat and engine? Can you also list the gear ratio on the lower unit as well.
