My boat is an 07 and the dealer put in 2 start batteries for the house power so I am in the same research mode as you. From the 3 hours of research I have already done this is what I have found.
Your wet cell batteries( the ones with caps that need distilled water) require TLC throughout the year. The water level need to be kept in check. Secured so it doesn't move and nothing can rub against it. On a trickle charger when not in use. Taken out and stored in a warm dry area during the off season with a trickle charger on it as well. They also need to be in a vented are as the omit a gas when charging that has the potential of explosion.
Next is a gel filled battery. It can be mounted sideways,(but I wouldn't). They are sealed so no water is required. They also admit very little to no gas when being charged so a vented area is not as important. If this type of battery gets a hole in it you wont get sulfuric acid all over the inside of the boat as you would with wet cell.
Finally AGM, Absorbent Glass Mat. It is a glass mat that is saturated with 95% sulfuric acid. There is no other water of aditives. It can not leak and mounts in any position. It also does not put out any gas when charging. These batteries charge up alot quicker and can rebound much better from deep draining or neglect. A quality charger is important with AGMs because there life span can be cut short from over charging.
Optima Batteries are the AGM type. Most people who have them swear by them. People that are unhappy with them seem to think that 2 wet cell batteries are better then the one optima. I am replacing with the Optimas for a few reasons.
1. No chance of sulfuric acid ever spilling and causing damage of other components.
2. The less gas produced in the engine compartment that could create an explosion hazard is always good.
3. Faster recharge times
4. Better life span so I don't have to revisit this problem for a long time.
5. Dead batteries out on the water is like being out of gas. You cant Mcgiver your way out of that one.
Will it be worth the money? If you can afford it I would say go for it. If it turns out to be a waist of money, Ill buy you a beer.
