Best location for temperature sender?
Wingnutt
In an effort to get the most accurate temperature of the engine, where would you consider the best location for the temperature sender?
1) In the intake manifold right before the thermostat housing to see the maximum temperature of the water exiting the engine.
2) In the head to see more of an average water temperature.
3) In the thermostat housing in a fitting that is pretty much even with the thermostat to see the water temperature at the thermostat?
180shabah
Re: Best location for temperature sender?
T-stat housing works for the manufacturers.....
