Best Material for Lining Inboard Engine Cover/Cowling???
DarkMountain
What is the best fireproof-fire resistant material to use to line and soundproof an engine cover for an inboard engine? The previous cover had a yellow foam substance about 1 inch thick.
Thanks in advance for your advice.
insanity
Re: Best Material for Lining Inboard Engine Cover/Cowling???
I don't know what it is but I have it on the inside of my dog house to. If it is still in good shape I would leave it. If you want more sound deadening look in to dynomat or something similar and put it under the vinyl on the out side of the dog house.
DBreskin
I suggest you post this question in the main "Boat Restoration" section instead of this Four Winns section. If a wider audience sees it you'll probably get a much better response.
