DWM76
- Joined
- Sep 4, 2018
- 47
Hi all,
I have been working on the old 68 Johnson 55hp (TRL-10R) and recently rebuilt the water pump. Being an outboard newbie I am not sure of the best method to verify it is working as there is no tell-tall and I believe water exhausts via the prop so with the lower unit in a barrel I'm not seeing flow.
At this time I am not supplying charge to the ignition system or any fuel, just turning the flywheel with the starter. (short bursts like testing compression)
1) Can I remove the thermostat and cover to check for flow to the water jacket?
2) How much of the lower unit needs to be submerged for the pump to move water?
3) I keep finding missing pieces - no trim tab...would this effect the pump function?
4) Should I remove the l/u and test by manually turning the drive shaft when submerged?
I feel like these are really dumb questions so I apologize for having to ask them.
I tried to check for flow once with the l/u submerged up to an inch above the intake screens, with the thermostat cover off and thermostat removed. No flow.
Driveshaft is turning prop shaft. Pretty sure intake and return water tubes are correct, they are visibly different.
Thanks,
Thanks,
