Re: Best Oil For Two-Cycle, Air Cooled Engine?
I think the difference is down the road, (or over the years). If you have ever taken a small 2 cycle engine apart that hasnt had the right oil used for its life span, it is not hard to tell. Yes, it was runnung right up till it died, but not at its potential probably for a few years, (or hours). I have, and the ones on synthetics were very clean with little if any deposits, and smooth cylinders, the ones with good quality regular 2 stroke oil were basically pretty clean with some carbon under the rings and some darker deposits, The cylinders were worn more, the ones that were run with whatever you got to run were very dirty, very heavy carbon deposits, and severly scored or froze up. These engines were everything from lawn mowers, outboards, weed eaters, motorcycles and the like. The performance you will recieve is directly in line with the quality of oil you run. A 2 cycle engine can freeze with any oil if ran lean, but we arent talking about that.
