Re: best option for flooring
I've had good luck with plywood and fiberglass. I restored a couple of boats with bad floors. First you cut the plywood to shape. If possible take the plywood almost right to the edge. Secondly, to make it last you'll want to paint it. I used Oil-Based paint and the water just repels right off it. Do at least three coats of paint. If you plan on putting carpet over the top of it just buy what my dad refers to as "Opps paint." It's the paint a customer returns because it didn't come out the right color. Nothing wrong with it. Usually you can get a gallon for $3. Hey, almost cheaper than gas! If you cover it with carpet you really don't care what color it is. Screw it down in a couple of spots and you're ready to glass. Using fiberglass isn't too hard. Buy some fiberglass cloth to cover up your seams. Cut the cloth to shape before you mix the fiberglass. Get some hospital gloves and double them up. Mix a small amount of fiberglass at a time. It dries up quick and you don't want to have a pan of dried up fiberglass. It's expensive. You might be tempted to buy cheap carpet but don't. If it doesn't have a good backing it might stretch out and look awful in a couple of years. On a rainy day you might want to check out this site before you start: http://www.uscgboating.org/safety/boatbuilder/index.htm
