Best place for Mercruiser tools?
sixman
I've got an ever growing list of tools I need but can't find a place that has all or most of them at a decent price - and suggestions?
So far I need....
Hinge pin tool
Shift cable tool - 9/16 socket
Bellows stretcher
Outdrive install tool
Also possibly alignment tool for the Gimbal bearing.
Alpheus
Re: Best place for Mercruiser tools?
That should be the first tool on your list...
Check eBay...
Don S
Hinge pin tool- Not needed, use 1/2" allen wrench, cut off a straight piece and use a socket on the cutoff piece.
Shift cable tool - 9/16 socket- Weld two sockets together
Bellows stretcher - most people use the tube and not the bellows, so tool is not needed.
Outdrive install tool - Whatever that is, assuming it's that thing that holds the shift slide, a dab of grease works just as well.
Alignment bar - Needed at least once a year when you pull the drive for spline and bearing service. Ebay or make your own. Drawing in adults only sticky.
mmajor97
Mr. Don, What kind of household items can I use to make a spanner wrench for the input shaft u-joint assembly? How about a bearing carrier puller?
Don S
Best thing to do is start a new thread with your questions, and not hijack sixmans post with something different.
mmajor97
I appologize, I assumed I was on the subject we were discussing in this thread.
sixman
Fine by me - I'm interested in the home grown ways as well!
Don - is the bellow stretcher only for the exhaust bellows? I have a tube currently but wasn't sure if the bellows was better/worse.
Don S
Yes, bellows only, not needed with the tube. The spanner wrench for the ujoint shaft retainer nut is a purchase item.
The alignment tool is needed every time you pull the outdrive off, which should be at minimum once a year. Without the alignment bar, you will not notice if a rear mount fails or the front mount moves or something happens that gets it out of alignment. When they are out of alignment, it will destroy the coupler, and you have to pull the engine to replace a coupler.
zbnutcase
And the exhaust bellows CAN be installed without the tool.
sixman
Gotcha - I'm a bit confused on the exhaust - bellows vs tube but it sounds like I only need a tool if I'm going to install the exhaust bellows and that its not needed for the main & shift cable bellows - sound right?
slag
So far I need....
Hinge pin tool
Bellows stretcher
Hinge pin tool -- Get a 1/2 inch TORX socket from Advance Auto and pull it out of the socket holder and turn it around. It works great and wont strip out even with air tools. Cost me 6.99.
Shift cable tool - 9/16 socket --Normal socket from Sears works with nut welded on top. About 10 bucks
Bellows stretcher - Not needed, waste of money
Outdrive install tool -- ?
alignment tool for the Gimbal bearing-
Most swear by it, but I feel it is not needed. However, Amazon.com has probably one of the cheapest ones out there that works.
Don S
LOL, there's one in every crowd.
First of all, the alignment tool is not for the gimbal bearing, it's to align the coupler to the drive. The gimbal bearing just holds the other end of the drive shaft so it doesn't flop arround.
Don S
Nope, not needed. I've been putting drives on for well over 20 years and have never used it. Like I said earlier, a bit of grease where the roller goes into the guides holds it in place nicely when installing the drive.
clockwatcher
I don't think it's been mentioned, but you need an outdrive oil filler pump and a dedicated grease gun with Merc grease. Some liquid electrical tape is handy for the wire connections on the motor and trim pump. Dielectric grease in the cheese-wiz type can works well to fight corrosion too. How about an Oil-Boy or the like to change your engine oil. Just a few things that come to mind.
slag
Right, but not needed if all you are doing is pulling the outdrive and replacing the gimbal bearing as the relative position of the gimbal bearing and coupler will not change.
Don S
Ok, what ever you say :rolleyes: :rolleyes:
Brewman61
Ensign
Right. No bellows stretcher needed for the u-joint shaft bellows nor the shift bellows. It is designed for the near end of the exhaust bellows.
sixman
clockwatcher - good point. I'm still not sure what to lube, grease, tape and/or otherwise coat with a oily substance. Need to get those on the list as well.
