Hello, while I was winterizing this year, my hand oil pump gave out and I was not able to drain the engine oil from my 89 Regal 4.3 V6 mercruiser. This has taken forever in years past. Is there a DC powered oil pump that really works available. Or do you use the drain plug in some fashion, cannot get an oil pan under the plug. Will have to wait to spring to change the oil. I always have run the engine up to normal ops temp before changing.
Thanks!
Thanks!
