Re: Best prop
that's to low, you've been lugging your engine.
I think my prop hub may have been slipping at that rpm
i don't know how that could be. if your hub slipped your engine would race wildly. no load on it because it's not spinning the prop. + no fwd motion due to no connection between the prop and the prop shaft short of any friction that's left after the spun hub. usually ya can idle fwd. with that little friction that's left..
imho, if your prop is contributing to low wot rpm, i would guess it would be because of the bent blade(s) or the loss of the tips that you describe in your first post on this thread.
what are your compression numbers?
i'm about out of spec on mine. they range from 125-150. majority of them at 130-135. i got one high one and one low one. and the spread is to wide..
compression test...
for sure let us know how that prop works for ya. i'm real interested. cool that you'll be able to try anything from 21p-15p... i'm guessing that 21 will be too much (you'll not reach wot spec of 3900-4300). and 15 will launch you like a rocket but you'll hit wot spec. before ya got wot... just a guess.. keep us updated mj..
edit.. do your tests with your normal load and normal trim. for me that's my regular on board gear + 1 cooler and two people. trim set between the 2nd and third marks going up from full down.. maybe getting close to the third mark..
my trim limit was doa when i got the boat. only thing i'm aware of on my boat that don't work proper..
not the end of the world though. just gotta be careful i don't trim to high...
