best spark plugs
jarata
I have a mercrusier 3.0 stern drive the plug it says to use is the ac-delco MR43T does anyone know of a better plug cross referenced or is this plug fine
ArkBoater
Re: best spark plugs
You are going to get a lot of opinions on this one. I just replaced mine (in mercruiser 3.0) and the previous owner had Champions in it, and I replaced it with NGKs. Good luck. ;)
tashasdaddy
i agree the engine was designed to run on a praticular plug. run what it was designed for.
Scaaty
Never had a problem with the AC's in my 350 (called for).
I seem to have terrible luck with Champs in the Harleys, (fine for the lawn mowers)
I have become a heavy fan of NGK though. Run fine Harleys and dirtbikes, the small outboards.
NGK BR6FS is the AC/cross..
A chart..
http://www.clubplug.net/cross.html
dave4151
I've been using NGK BR6FS in place of ac-delco MR43T for 3 years and haven't had a problem.​
PhatboyC
I have OEM now but my next set will be NGK Iridium's. Simply for longer change interval.
