Re: Best technique for Perfectly smooth surfaces?
I have used epoxy resin cab-o-sil and microballoons to fair the deck of my old tug. I am a novice and when I started the job I knew absolute zero about the task. I used what I learned in here as well as advice from the resin maker.
Looking back I would have done it a little differently.
First make a test batch of your compound. I first used the ratios recommended by the resin maker. It yielded a very thick compound that was difficult to spread. After playing with the mixture awhile I found what worked best for me.
Second, schedule your sanding times closely with the cure time of the resin. Unfortunately for me, work often prevented me from sanding the cured mixture until nearly a week later. In the heat of the summer a week is too long. It made sanding very difficult.
Third, prep the surface to be faired completely before starting application. I highly recommend any prep work or repair to be done completely without exception before starting.
That means have everything ready, including all the supplies you will need. Have enough resin, hardener and filler. Have plenty of mixing pots, stir sticks, gloves, spreaders ect. It is a real pain having to stop and go get more stuff.
The ideal situation would be to have all the repairs and initial prep work done. Then apply the fairing compound, mixed to a usable ratio, to the entire surface to be faired. Then start the sanding as soon as the resin cures to a sandable state.
You can see some bits and pieces of my fairing job in the links below. Truthfully, it is not a job I ever want to have to do again, but I am very happy with the result.
