Best type of wood to use
Chris_94_Sprint_TX
I am looking to find out the best kind of wood. I know the optimal choice is marine plywood. However, if a budget is tight is there another type of inexpensive wood that can be used with the proper sealing procedures. I know treated lumber is not a good choice.
Chris
pckeen
Re: Best type of wood to use
Hi Chris,
Lots of people use Aruco plywood. You can also use exterior grade plywood (not treated),which is the cheapest option.
Chris_94_Sprint_TX
What about sealing, could regular Fiberglass resin be brushed or thinned and sprayed over the wood after being cut and before being assembled and installed.
Chris
matt167
Only exterior grade plywoods should be used as they have exterior glue. Avoid CDX. ACX or BCX will be ok. You could also use ABX if you can find it.
MDO is Medium Density Overlay and is a plywood product made with douglas Fir and exterior glues. It is a good quality product available most anywhere and will work also
jigngrub
MDO isn't a good choice for fiberglass construction unless you're going to use epoxy resin instead of polyester resin. MDO has a phenolic coating which is basically epoxy and polyester resin won't bond well to it if at all.
mwe-maxxowner
Ahh carp! Wrong thread! My apologies!
