havoc_squad
- Joined
- Mar 5, 2011
- 739
What is the best value pre-made polyester compatible fiberglass filler product out in the market today for significant quantities used as Fiberglass PB? Or is there a proven less toxic alternative filler than cabosil that can be used?
If it is premade, preferably one that has the wax in it so I don't have to put PVA or wax on it to cure. Or does PVA spray easily wipe away with a wet rag so I don't have to worry about getting water on uncovered wood not ready for fiberglass & resin yet.
Reason for asking is that I have an upcoming fiberglass floor and very likely stringer project likely for next spring and I really do not want to mess around with Cabosil to make fiberglass PB given how highly toxic it is given how easily airborne it gets.
Yes, I plan to be using a P100 grade respirator filter particle filter with organic vapors filter for the chemicals.
I know of 3M, Evercoat, and a few others make short and long strand versions of this product, just wondering if there are cheaper options than them available via retail.
