Re: Best way to apply mat and poly resin on new deck?
Sorry Chief<br /><br />I do Polyester for a living, I currently work for a very large polyester resin and gel coat company in technical service and sales. At the last company I worked for, I was in charge of the marine market in North America, then that company was sold to a larger one. At one time or another I have been into most large boat builders in the US and Canada. <br /><br />My job now is to recommend specific resins and gel coats for each application, then teach and assist them in using the products correctly. This is not only in the marine industry, but all products made with resin and gel coat.<br /><br />On this project there is no problem with resin coating the wood, then letting it get hard. You do not need to finish a polyester layup all in one session, if you did then almost every boat made today is done incorrectly. If you use a resin with wax in it, or a DCPD based resin, then yes, it should be sanded before the next layup if it sits too long. If you thin the resin very much, you will only weaken it, styrene will make resin brittle if too much is added.
