Well i got the chain for free. Some sites say that Your chain length should be as long as your boat. I can always shorten the chain. The chain is attached to 200 feet of 1/2 rope
Yeah, I'd say 10' of chain is plenty on a 27ft boat, and 150ft of good anchor rode is sufficient as well. I would hate to have to haul up 40 ft of chain when you pull up anchor; that will wear you out quick! The scope of the anchor line is going to give you that good hold, the 40 ft of chain is just piling up on the bottom of the bay.
I kinda of have to disagree, and here's why.
The more chain you have out the better "shock absorber"? you have when dealing with waves and wind.
If you used just the rope/rode portion, it would be tight from the anchor to the boat, with enough chain out, the chain section being heavy should weight down the rode giving you hopefully an "easier" less jerky movement everytime you get hit by a wave.
I know this started with anchoring in 5 feet of water, but I just wanted to add why the chain is required
I guess you could do the tie the rope to the tree thing, pull on the rope hard, then add an 100 pound weight to the centre of the rope and pull, that would be the shock absorber thing.
my take on it anyways.![]()
I was not arguing whether the chain acted as a good shock absorber, it absolutely does. However, 40' is excessive in probably 99% of the cases. If you're in a 268 and 10' of chain plus proper scope isn't holding, you may be in some pretty nasty seas for a boat of that size.
I use one of these.
