I'm with Belchy on this....never just set the loop of the rope on the little hook. There's no guarantee it'll stay there with an aggressive skiier who may let the rope slack at times. <br /><br />But I think maybe I can clarify a little how to do it. You have to feed the loop in the rope down from the top in-between the boat and the eyelet (not from under the eyelet, ABOVE the eyelet), then pull the loop down and under and back thru the center of the hole TOWARDS the boat, and NOW set the loop in the hook.<br /><br />Clear as mud, eh? I did find this post which may help:<br /> http://www.skitube.com/index.asp?PageAction=Custom&ID=15 <br /><br />The second picture clearly shows the end result...but it looks like this loop is backwards to me, or the rope is pulling the wrong direction. But you get the idea anyway.<br /><br />Well...at least Belchy and I know what we're trying to explain...<br /><br />That post shows how to attach to an inflatable as well...depends on the type of harness. Istructions should explain it clearly.Originally posted by Belchy:<br /> Those kind of fittings, (that boomyal showed are great) I find that the best way to attach the rope is go feed the splice in the rope under the eyelet, and then go up and over the center hook, this provides more even wear on the rope and doesn't let the rope fall when there is slack in the line..<br /><br />Hope I explained well enough without confusion.<br /><br />Belchy
absolutely!<br /><br />IMHO, the only justification for using a harness, attached to the stern eyes, is if you have an outboard and do not have a ski pylon that clears the top of the outdrive.Originally posted by 74Baja:<br /> When I tow a tube in my Baja (usint the tow harness and transom eyes), since the boat is so low, it seems to plow the nose of the tube into the water. I do have a tripod for skiing. Is this good to use for the tube?
