Re: Best way to clean a carb?
Sockeyerun has some good advice. I would like to add a caution if you plan to remove and clean the carbs properly (and it's really the best only way to clean them right)...You mentioned soaking the carbs. This is fine,but this type of cleaner is very thurough ,TOO thurough. Emulsion type cleaners will disolve rubber,plastic,hard carbon deposits and gasket materials.<br />So the carb must be totally disnmantled to remove all plastic and rubber parts,such as vale seats,riser floats ect.<br />If you would rather try to clean the carb without completely tearing it down, your best bet would be to stick with the spray stuff. These can be quite effective,if you partially dissmantle the carb (remove float and float valve), and use the spray to clean the ports and parts. Pay particular attention to the pickup tube and the rest of porting,by spraying the cleaner thru the ports and jets. You should wear eye protection when doing this,because the spray you spray in, comes out in unexpected places.<br />Order the rebuild kit, and use the expensive spray cleaners (they work twice as well in some cases).<br />I've had good results with the Valvoline carb cleaner. It has a "wand" that should be patented,if it hasn't been allready.
