best way to paint a boat?
stinkbait85
i am simply curious to find out what the easiest way to paint a boat is. upside down? or suspended? i am starting a project that will take quite some time but i want to do it right. i have decided that any painting on the inside of the boat will be done once it is back on the trailer. i have never painted anything using a paint gun or obviously a boat. so any helpful advice will be most greatly appreciated.:):)
ezmobee
Re: best way to paint a boat?
Easiest by far is upside and rolling something like Easypoxy or Rustoleum on it. If your existing finish is in good shape and not flaking you can just scuff it up well and not even have to prime.
SoonerD
First of all, I'm assuming you are painting an aluminum boat. I too was new to this just a few months ago and have been painting my boat the last couple of weeks and just finished yesterday. The best advice that I can give you is educate yourself on the different paint options and decide if you are planning on using a clear coat over paint because you don't want to use a clear if you paint with an enamel. In no way am I a professional painter and like you had to use resources to learn the steps and get past the intimidation of painting a boat. Here are the steps that I went through on my aluminum boat.
-Used Citra strip Stripping Gel that doesn't contain methylene chloride! It was non-toxic and very low odor.
-Used a wire wheel to sand down scratches.
(I stripped & sanded because I was changing colors of boat)
-Used PC-11 to fill in any deep scratches
-sanded entire boat with 80 grit paper (scratch it up so primer will adhere).
-Applied self etching primer.
-Wet Sanded using 400 grit.
-Cleaned it really good with soap & water (Very Important-before applying paint use Denaturated Alcohol to make sure surface was really clean).
-Applied first coat of paint and let dry for 48 hours.
-Wet sanded using 1000 grit paper which got rid of any orange peel.
-Again cleaned the boat thoroughly
-Applied second coat of paint.
-I then plan on color sanding and buffing to bring out the shine.
I would recommend turning the boat over, which I had done at a marina that had a hoist. They had it turned over in about 15 minutes. I sprayed using a gravity fed gun and because the paint was self-leveling it turned out very nice. You can also use the roll & tip method if you do not want to spray. If done right, it's hard to tell the difference. The last thing is please make sure you wear a respirator with charcoal cartridges when you are painting...Good luck. Again I'm not a professional painter, but I'm pleased with the results.
Free Bird
Upside down if you can. Do a search for roll and tip on Youtube to see the technique in action. Use 4" foam cabinet rollers from Home Depot and foam disposable brush for tipping. I studied and studied threads on the internet and did Awlgrip on a fiberglass boat in September. It looks sprayed.
