Best way to seal holes/gaps in an aluminum hull?
gunner1
Went to take my 1967 Starcraft aluminum hull boat out today and noticed water coming in from the rear transom area. When I got it home, I noticed some holes in the transom where it looks like some rivets are missing. What's the best way to fill/seal them? Also, I'd like to seal the seam that runs along both sides of the keel. Would 3M 5200 be good?
Shawn Acker
Re: Best way to seal holes/gaps in an aluminum hull?
I personally would TIG weld it. are you around houston, texas anywhere.
I have a lummie to TIG up this weekend. You bring the beer ill bring out the welder.
gunner1
Only if you consider New York close to Houston! Thanks for the offer though.
rolmops
If you have a fastener store in your area yo may want to take them one of your rivets and ask them if they sell stainless steel truss headed phillips screws about half an inch to an inch longer than your rivets.The same thickness as your rivets of course.Get these with washers and nuts.These are not your local home depot product,you have to go to a place that specializes in fasteners.
once you have found them you can drill out all the loose rivets and replace them with your truss headed bolts that have the same shape as your rivets.In fact,you can replace every single rivet in your boat with them.It would of course be smart to get some marine sealant on the inside of the bolts.
tashasdaddy
stainless nut and bolt with rubber washers. if it was rivets missing they were holding something.
dimock44
3 m 5200 takes 7 day to cure and 2 day to tack over. I put it in the water after 2 days and it held. I keep my boats in a boat house and try to bring them up to the shop as little as possible. For quick repairs I use gutter seal. Holds pretty good and suprisingly is sort of gas resistant
Bob_VT
Take that advice seriously...... I doubt random rivets are installed and you might even want to get some pop rives that fit the hole..... you can measure the length (grip depth) with a piece of wire. You really should make sure you are keeping things attached. You can put some 5200 on the rivet before you pop it and a dab over the head. It will last.
1730V
If rivets are missing, they need to be replaced. You can use aluminum pop rivets. Make sure the aluminum rivets have aluminum centers-not steel.
Once riveted, the best sealer for aluminum boats, by far, is Gluv It. It is best applied from the inside of the boat.
Gluv It is available here on iboats.
iwombat
You can use closed-end aluminum blind rivets to seal all that up. Make sure they have aluminum mandrels. A little marine-tex on the shaft doesn't hurt either.
Find a source online and order a big bag. That's not the last rivet your old tinny will pop, and it's good to have replacements on hand.
buckstop108
Not meaning to highjack this thread, but, What causes a rivet to pop? I have a 1992 Lund with carpeted decks and finished gunwhales if a rivet should pop I assume that I would have to take up the decks to make the repair and hope it is not in an area that they sprayed the foam. Is this correct? I am assuming that a rivet can not be repaired from the outside of the hull.
Shawn Acker
to answer the question you do want to put in the rivet from the outside. If you put it in from the inside it will not be flush.
Arlo
gunner1
I have a pontoon that I used Alvin's Aluminum Bondo to repair the holes and all works great.
http://www.alvinproducts.com/Products/Content.asp?id=2
How would I best seal the holes using this? Could I put a piece of plywood behind it, spackle over the holes, let it cure, then remove the plywood sheet? Or would it be best to just stick some screws with sealant on them in the holes?
cuzzx
it works like bondo , just smooth it on the best you can, let dry then sand smooth.
reelfishin
I've also used Marine Tex or several other aluminum filler type epoxies.
All work well but when it comes to missing rivets, I'd replace the rivets first.
AZMinyard
Take a look at the following thread:
http://forums.iboats.com/showthread.php?t=225499
"Mr.Stuart" used a aluminum welding product to fill holes/cracks with some fine results. I was able to find a similar product at Home Depot.
At any rate, it is a great thread and well worth reading!
