Best years of 115
mobilef
I gonna be shopping soon for a older 115 and was wondering the best years to get and which years to stay away from... Thanxs in advance.
jimmbo
Re: Best years of 115
How old do you want to go? In 74 they increased the size of some of the bearings, thus the 73s and earlier had some troubles. In 73 they ditched the hydro-electric shifting and switched to a hydro-mechanical design. Somewhere around 77 or 78 they scrapped the hydro-mechanical shift and went to a plain mechanical shift. During the 70s and 80s various ignition systems were used each with its own problems. The 1969 and 1970 models were 96.1 cu.in. blocks, the 1973 and later were 99.6 c.in. In 95 or 96 the 60 degree blocks were introduced.
duck64
Originally posted by jimmbo:<br /> How old do you want to go? In 74 they increased the size of some of the bearings, thus the 73s and earlier had some troubles. In 73 they ditched the hydro-electric shifting and switched to a hydro-mechanical design. Somewhere around 77 or 78 they scrapped the hydro-mechanical shift and went to a plain mechanical shift. During the 70s and 80s various ignition systems were used each with its own problems. The 1969 and 1970 models were 96.1 cu.in. blocks, the 1973 and later were 99.6 c.in. In 95 or 96 the 60 degree blocks were introduced.
duck64
made a mistake, mine is a 96 johnson 90 degree i'm told. are they good motors.
G DANE
The new 90 deg are turque monsters, Strong Motors
mobilef
The 70's or 80's years are fine...plus they were probaly better built then huh.
Dhadley
The 120, 130, 135 and 140 V4 loopers loopers are indeed torque monsters. They started showing up in 1985. The 60 degree 90 and 115 are lighter than the 90 degree looper and real snappy. They were born in 1995. The crossflows are old technology but very well proven thru the years.<br /><br />Tough decision.
ledgefinder
Ensign
Really all of them from 1969 on up can be good motors, it more depends on the condition of the particular one you're looking at. Obviously a newer one has a better chance of being low hours.<br /><br />As has been said, from 1969-72 they have hydro-electric shift and a battery CD ignition - both of which can be a bit difficult to get parts for.<br />There isn't a real strong basis for choice between the various flavors of 115 from 1973 on, IMHO, just the gradual improvement in condition due to the fact that you're dealing with a newer motor. All the 1973+ crossflow V4s are good strong reliable units.<br /><br />My first choice would actually be a 1986 or newer 88/90hp. The horsepower ratings were changed in 1986, and the old 115 flatback became the new 88/90hp. Just the right level of tune to be strong but still reliable - in fact I think the horsepower rating is a bit of a 'sleeper'.<br /><br />The older 85hps (1980 and older) are de-tuned so much that you do lose some usable top-end horsepower.
JB
To Outboard Non-Repair
mobilef
Originally posted by ledgefinder:<br /> My first choice would actually be a 1986 or newer 88/90hp. The horsepower ratings were changed in 1986, and the old 115 flatback became the new 88/90hp. Just the right level of tune to be strong but still reliable - in fact I think the horsepower rating is a bit of a 'sleeper'.<br /><br />The older 85hps (1980 and older) are de-tuned so much that you do lose some usable top-end horsepower.
So are you saying that is pretty much the 115 but just rated lower and would that motor be a better choice than an older 115... Thanxs
JasonB
I believe the '74-'77 85hp is a slightly different animal. I understand that my '76 85hp Johnson is a few cubic inches displacement less than the 115's. They are 99.x and I think my 85 is 91.x? That being said, my 85 xflow is a stump puller and still runs strong.
jimmbo
Originally posted by bmcgee1:<br /> made a mistake, mine is a 96 johnson 90 degree i'm told. are they good motors.
When the 60 degree V4s were first introduced, they were sold along side the old 90 degree motors for 2 years, at least in Canada they were.
jimmbo
The 1969 thru 1978 85hp were 92.6 cu.in. blocks in 1979 they were switched to a 99.6 block.
