Oshawapilot
- Joined
- Aug 2, 2013
- 66
With the ignition system issues on the problem child engine finally (hopefully) coming to a close (see my other threads), I'm starting to turn my eye towards the start system.
The engine has always been a bit slow while cranking...and while looking at the slave start solenoid yesterday I noticed that it is getting old and crusty. Yes, the main cables coming from the battery are not in A1 condition either, so they will get some attention as well.
So, I have a basically new unused starter relay in my garage that I was contemplating brining up to swap it out with just to rule out the old and crusty solenoid as a possible reason behind the cranking issues..however, when I started reading things more here I soon realized that the starter solenoid on the 470's is actually on the starter itself. Not sure how I missed that during visual inspection, but anyhow.
My question is WHY is there two start solenoids - the slave, and then the actual main solenoid on the starter itself?
Can the slave be eliminated removing a possible point of failure/issues, and just wire the ignition switch trigger wire directly to the starter solenoid like most vehicles have it?
In short, I'm not fully grasping what the separate slave solenoid does aside from provide a full 12V source of power to the coil during cranking, but that would be very simple to route from elsewhere during starting, no?
