michaelfbush
- Joined
- Nov 6, 2005
- 10
Check out your after market oil seals. I just had a blow out. Sierra sent me 4 oil seals with plain STEEL tension springs. I put them in. Then I put the boat in salt water and two days later oil on the prop. Took it apart....springs rusted apart....went to Evinrude dealer and got the right ones. The OEM versions where a might bit more on the stout side I might add. For me, now on, only OEM oil seals! <br /> I think the springs should be 302 stainless steel. They should have only a slight stick to a magnet. What was left of the Sierra seals stuck but good.
