roozterdvx
- Joined
- May 29, 2006
- 57
Previous owner had installed a Stingray hydrofoil. I'm not a fan of these things but didn't feel the need to remove it until...
I found a crack in the anti-cav. plate and after further inspection, a chunk of the plate was completely broken off on one side, and only held on by the hydrofoil bolt that went through it, and bent up on the other side due to the force applied!
I removed the foil , prepped and welded the section of plate back on, and then reinforced the anti-cav. plate with a piece of 1/4" thick x 1" wide aluminum bar bolted on using the holes for the hydrofoil.
The boat has hyd. trim tabs, and although it got on plane a little quicker with the foil, I don't understand why the P/O installed the POS foil.
