BF 50 will not run up under load
kenwitt
Need help again.. shes pumping .. good solid test stream.. will idle forever at 1000 rpm.. will go into fwd or reverse and run at approx. 1200 rpm under load forever but dies when I try to advance the throttle.. revs up in neutral .and . in gear on micky ears..<br /><br />Clean fresh fuel.. my get home Johnson runs fine on the same fuel..Tank vent open<br /><br />Ps over 3 wks now and still no FSM..must be shipping from Japan!!!!!<br /><br />All your help is appreciated very much... TX ken
TOHATSU GURU
Re: BF 50 will not run up under load
I would take a look at the high speed jets. If you have done that...do it again. Maybe even a third time. It really does not take much to close off a jet. If that doesn't do it think hard about taking it to a dealer( a not stupid dealer). Any brand will do. Honda technology is nothing special on that engine.
phatmanmike
whens the last time carbs were rebuilt and cleaned and soaked?
