BF 90 (2001) High Voltage Output
weltiro
Voltmeter pegged past 16 volts, measured 30 volts across battery terminals. Afraid to blow up battery. Bad regulator or retifier? Otherwise, engine is running great and all eletronics work.
Update:
Mechanic came out, checked everything and said charging system was OK, put the gauge was bad. I put my meter back on and got 14V with engine running. I am puzzled. Maybe it is an intermittent problem?
