Bf100 wont fire
bubsacle
my bf100 wont fire,its getting spark and fuel and it wont start. Its a pull start. its occasionally backfires which indicate a timing issue but im pretty sure its timed correctly. Ive lined the 2 dots up together on the cam pulley. Ive aligned the T up with the support stand closest to the cam pulley. Is this correct or am I missing somthing? any suggestions would be very helpful.
:confused:
hondon
Re: Bf100 wont fire
Sounds like you are timed correctly.If the valves are properlly adjusted and compression numbers are even,then you have to look towards that carb.
