MIKENVAHBEACH
- Joined
- Apr 20, 2003
- 84
2004 BF225 (800 hours) on a 22? Pursuit, boat is run coastal all year long never winterized. In 2007 the stern was enclosed, a bracket was installed and the fuel tank was removed from the boat, cleaned, pressure tested, and exterior of the tank was painted with coal tar epoxy. The tank was reinstalled and the boat ran fine for several months; since last summer I have been fighting the typical ethanol fuel problems with water in the tank and the white powder in the HP filters. The tank has been drained and fuel replaced (3 times), HP filter and pump have been replaced, fuel rail and injectors have been cleaned, plugs replaced, new fuel lines, and new twin Racors (30 mic and 10 mic). The boat ran great for 3-4 months, however I ran it outta Oregon Inlet two weeks ago and fished about 40 miles offshore and the boat ran home fine no problems, the next morning I cleared the inlet again and the boat started losing power like water in the fuel (seems like the same problem I had previous year), the Racors either were completely full of water or fuel I could not tell, but I drained and replaced them however it did not correct the problem, I limped home. Once home, I drained the vapor separator(again), replace the HP filter (again), replaced the Racors(again); maybe a teaspoon of water was observed when I drained the fuel from the HP pump. Now the fuel cut-off solenoid is pumping gas straight out the vent tube so I am replacing this part. Are these series of events related? Am I missing something? I have been polishing the fuel with a series of Racor water sep/filters and an old fuel pump, but since this is occurring when the boat is on the trailer I feel it is doing little good, since if there is any water it will be settled at the bottom of my tank. Maybe need to polish the fuel while driving the boat around on the trailer to shake the fuel up? Any input would be appreciated I?m getting frustrated!
-Mike
-Mike
