Hi All,<br />Got a question. I'm having a cylinder drop out when I back off the throttle quickly, then it stumbles a bit and usually kicks back in. It definitely fuel related. I've checked everything and I've narrowed it down to a carb problem. <br /><br />My question, (yes I have the manual) When you go to remove the carbs, do you take the entire Intake manifold off with carbs attached or do you take the carbs off individually. The manual is a bit unclear and I'm trying to save a bit of work if I can. It seems taking the mainfold off then separating the carbs is the way to go.<br /><br />Nav
