Hi...i'm new to the board and I have a problem with BF90(1999). When I start the engine and its cold it idle ruff, hic-ups and studders when reved up. It has also had bad fuel consumption.<br /><br />When I took a vacuum reading at the intake, it drifted between 10 and 20 inches of mg. (this was the same at every carb). This all started this season.<br /><br />I have replaced the spark plugs and changed all the fuel filters. I have also cleaned the carbs, reset the pilot screws, replaced the intake gasket etc. Also i did a compresson test and all the cylinders are equal. I've tested for vacuum leaks with my tester and have found zero.<br /><br />I'm starting to think this is a ignition problem. My question is has anyone had this problem before?
<br /><br />Any input would be great.<br /><br />thanks KC
