Re: Big Battery Problems
SOunds like your starter is fried. Could also be an underpowered(low amperage) battery. Bad thing to do. you over stress the winding in the starter motor. Then the end of the windings that are soldered/braized in the starter begin to come loose.<br /><br />Course the cylinders could be hydraulicly "locked" if fuel flooded the cylinders. Can you turn the motor by hand?
