Our old perko masterswitch was broken (actually cracked, and one battery position does not work) and had to be replaced. The owner of a nautic shop where I use to buy stuff, a gentleman and ponderated person, showed me three masterswitch models when I told him I needed to replace it: the same perko model (expensive), another red model very similar (almost identical) to the perko model but chinese I think, and a big black masterswitch korean made. The last one looked to me very robust and well constructed. The case is made of phenolic resin (like black plastic, but with a surface harder than plastic, the same material used in old Simpsom multimeters). The control knob is big and has a red latch you have to press to change position. The posts on the back are copper, very robust. The back of the case has SS screws on the perimeter (6 to 8, dont remember exactly) so you can open and clean or eventually try to repair. This gentleman told me that he installed one of those korean masterswitches and it works perfectly; told me to buy it with "closed eyes". At the first glance it looked to me that the black switch was the most expensive, because of the size and robustness, but resulted to be a bit cheaper.<br /><br />I made the purchase, as the man is a trustable person in my opinion.<br /><br />I will install the switch saturday morning.<br /><br />Would like to know if you have used one of those.<br /><br />thanks in advance,
