cordell
- Joined
- Mar 28, 2008
- 308
OK so I have another issue. Without this site I think a rubber raft hole would be a hard patch job! Seriously though everything I need a answer to is here so I will try to stump you all again.
My new to me Bayliner Capri 1990 in year and 18' in length has holes for the motor that used to be on the boat. I want to add my 1987 85 hp Force motor to it, this is were the problem comes. The pic shows my hole pattern that is OK to a point. The top 2 holes need to be sealed up. The bottom 2 work for my motor. The down view of my transom has a measurement of 3 inches. Well you see my motor has the 2 screw type fasteners for the top and that measures 2.5 inches. I need 1/2 inch somewhere!
I was thinking take the screw type fasteners out and running lag bolts into my transom???? Is this the correct fix, or the oak ball way? If it is the oak ball way what do I need to do that doesn't involve me buying a different motor OR motor mount for my motor...The top 2 hole do not line up with the screw type fasteners either so adding some heli coil will not work, unless I fill them and drilled new ones? HELP lol
thanks
cordell
holes
top 3 inches
motor mount 2.5 inches
thanks
cordell
holes
top 3 inches
